Configure CFM MA
You must configure a CFM MD.
Use this procedure to configure a CFM Maintenance Association (MA). An MA represents a logical grouping of monitored entities within its Domain. It can therefore represent a set of Maintenance Endpoints (MEPs), each configured with the same Maintenance Association ID (MAID) and MD Level, established to verify the integrity of a single service instance.
- Select CFM.
- Select the MD tab.
- Highlight an existing MD, and then select MaintenanceAssociation.
- In the MA tab, select Insert.
- In the fields provided, specify an index value and name for the MA.
- Select Insert.
MA Field Descriptions
Use the data in the following table to use the MA tab.
Name |
Description |
DomainIndex |
Specifies the maintenance domain entry index. |
AssociationIndex |
Specifies a maintenance association entry index. |
DomainName |
Specifies the MD name. |
AssociationName |
Specifies the MA name. |
NumOfMep |
Indicates the number of MEPs that belong to this maintenance association. |
